Zum Hauptinhalt wechseln
Dell XPS 15 9500 SSD Replacement
Was du brauchst
  1. Dell XPS 15 9500 SSD Replacement, Base Panel: Schritt 1, Bild 1 von 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 SSD Replacement: Schritt 2, Bild 1 von 2 Dell XPS 15 9500 SSD Replacement: Schritt 2, Bild 2 von 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 SSD Replacement, SSD: Schritt 3, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove the single 3.0 mm screw on the right side of the SSD.
  4. Dell XPS 15 9500 SSD Replacement: Schritt 4, Bild 1 von 1
    • Lift the card a few millimeters, then pull it directly out of its slot.
  5. Dell XPS 15 9500 SSD Replacement: Schritt 5, Bild 1 von 2 Dell XPS 15 9500 SSD Replacement: Schritt 5, Bild 2 von 2
    • If you wish to install a second SSD, there is an empty slot for an additional SSD underneath the copper cover. If you're just replacing the existing SSD, stop here.
    • Use a Phillips #000 screwdriver to remove the one 3.0 mm screw on the left side of the SSD slot.
    • Pull the cover out directly toward the left.
Abschluss
Bryan Chung
437 Reputation
4 Anleitungen geschrieben
UC Santa Barbara, Team A-1, Bator Winter 2022 Mitglied von UC Santa Barbara, Team A-1, Bator Winter 2022
UCSB-BATOR-W22SAG1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 23
Letzte 30 Tage: 87
Insgesamt: 4,804
