Zum Hauptinhalt wechseln
Dell XPS 15 9500 Speaker Replacement
Was du brauchst
  1. Dell XPS 15 9500 Speaker Replacement, Base Panel: Schritt 1, Bild 1 von 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Speaker Replacement: Schritt 2, Bild 1 von 2 Dell XPS 15 9500 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the two 3.0 mm screws (one on each speaker).
    • Use an opening tool to lift out the speaker.
  4. Dell XPS 15 9500 Speaker Replacement: Schritt 4, Bild 1 von 2 Dell XPS 15 9500 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Use an opening tool to push the left speaker's cable out of its port until it is disconnected.
    • The speaker on the right side isn't connected to the motherboard, and is only connected to the left speaker by a wire at the bottom.
Abschluss
Bryan Chung
437 Reputation
4 Anleitungen geschrieben
UC Santa Barbara, Team A-1, Bator Winter 2022 Mitglied von UC Santa Barbara, Team A-1, Bator Winter 2022
UCSB-BATOR-W22SAG1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 1,065
