Zum Hauptinhalt wechseln
Dell XPS 15 9510 Display Assembly Replacement
Was du brauchst
  1. Dell XPS 15 9510 Display Assembly Replacement, Rear Panel: Schritt 1, Bild 1 von 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Display Assembly Replacement: Schritt 3, Bild 1 von 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Display Assembly Replacement, Display Assembly: Schritt 4, Bild 1 von 1
    • Remove the four screws (eight total) from each display hinge using a Phillips #00 screwdriver.
  5. Dell XPS 15 9510 Display Assembly Replacement: Schritt 5, Bild 1 von 1
    • Remove five screws that connect the display using a Phillips #00 screwdriver.
  6. Dell XPS 15 9510 Display Assembly Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove the display from the Dell XPS 15 9510.
Abschluss
Austin Sa
432 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 1-3, Mellen Spring 2022 Mitglied von UMass Dartmouth, Team 1-3, Mellen Spring 2022
UMASSD-MELLEN-S22S1G3
3 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Missing a very important step.
Two small screws above the display cable clamp - Step 5 - need to be removed. If you look at the picture in step 5, the far left red/orange circle actually contains one. You can spot it inside and at the top of the of the circle. You can't separate the display assembly without removing those 2 screws.
Joshua Kleier - Antwort
Aren't there any cables that need to be removed?
Ned Eff - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 89
Insgesamt: 2,991
