Zum Hauptinhalt wechseln
Dell XPS 15 9510 SSD Replacement
Was du brauchst
  1. Dell XPS 15 9510 SSD Replacement, Rear Panel: Schritt 1, Bild 1 von 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 SSD Replacement: Schritt 2, Bild 1 von 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 SSD Replacement: Schritt 3, Bild 1 von 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 SSD Replacement, SSD: Schritt 4, Bild 1 von 2 Dell XPS 15 9510 SSD Replacement, SSD: Schritt 4, Bild 2 von 2
    • Remove the single screw from the left side of the SSD using a Phillips #00 screwdriver.
    • The SSD is spring-released; it will pop up after removing the screw.
  5. Dell XPS 15 9510 SSD Replacement: Schritt 5, Bild 1 von 1
    • Use your fingers to carefully remove the SSD from the laptop.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Austin Sa
432 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 1-3, Mellen Spring 2022 Mitglied von UMass Dartmouth, Team 1-3, Mellen Spring 2022
UMASSD-MELLEN-S22S1G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 29
Letzte 30 Tage: 84
Insgesamt: 3,624
