Zum Hauptinhalt wechseln
Dell XPS 15 9510 SSD Replacement
Was du brauchst
    1. Dell XPS 15 9510 SSD Replacement, Lower Case: Schritt 1, Bild 1 von 1
      • Make sure the laptop is powered off and unplug all cables before beginning any repair.
      • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. Dell XPS 15 9510 SSD Replacement: Schritt 2, Bild 1 von 1
      • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
      • Wedge the case apart with a nylon spudger.
      • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
      • Slide spudger along each side of the laptop
      Frag FixBot
    3. Dell XPS 15 9510 SSD Replacement: Schritt 3, Bild 1 von 1
      • Lift the back panel of the laptop off and set it aside.
      Frag FixBot
    1. Dell XPS 15 9510 SSD Replacement, SSD: Schritt 4, Bild 1 von 2 Dell XPS 15 9510 SSD Replacement, SSD: Schritt 4, Bild 2 von 2
      • Remove the single screw from the left side of the SSD using a Phillips #00 screwdriver.
      • The SSD is spring-released; it will pop up after removing the screw.
      Frag FixBot
    2. Dell XPS 15 9510 SSD Replacement: Schritt 5, Bild 1 von 1
      • Use your fingers to carefully remove the SSD from the laptop.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 1-3, Mellen Spring 2022 Mitglied von UMass Dartmouth, Team 1-3, Mellen Spring 2022
UMASSD-MELLEN-S22S1G3
3 Mitglieder
39 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 59
Insgesamt: 5,415
