Einleitung
Audio issues or sound failure in the Dell XPS 15 9510 indicates that the speakers located on either side of the laptop may need replacement. There are no special skills involved in the removal of the speakers.
Before using this guide, make sure to review the troubleshooting page to ensure that the speaker doesn't have any driver or any other issues.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
Was du brauchst
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Wedge the case apart with a nylon spudger.
Slide spudger along each side of the laptop
Remove the four 2.5 mm screws holding the speakers in place using a Phillips #0 screwdriver.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Lift the black tape that covers the power supply pin plug.
Begin removing the wire from the track on the computer body.
Now the speakers will be fully disconnected from the computer.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 weitere Personen haben diese Anleitung absolviert.
