Einleitung
How to remove/replace the Dell XPS 15 9530's Base-Cover Assembly (bottom panel) so that the laptop's components can be accessed.
The information and pictures in this guide have been taken from the service manual from this device, listed on the product page. If you need any additional information on disassembling this device, please consult the service manual.
Was du brauchst
After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare zur Anleitung
I need to replace these screws. What is the size, dimension, type?
There is no "system badge" which folds open on my Dell XPS 15 9530 (2023). It is solid aluminum, and has "XPS" stamped into it. The images published for this repair guide appear as if the bottom cover is made of some kind of plastic? Am I looking at the wrong repair guide?
