Einleitung
How to replace the 2.5" hard drive of a Dell XPS 15 9530.
Was du brauchst
Schritt 1 Unscrewing the Base-Cover Assembly
Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
Schritt 3 Remove Battery
Achtung: Schritt 3 stammt von einer Anleitung, die derzeit bearbeitet wird.
Remove the screws that secure the battery to the palm-rest assembly.
Disconnect the battery cable from the system board.
Lift the battery off the palm-rest assembly.
Remove the screws that secure the hard-drive assembly to the palm-rest assembly.
Using the pull tab, disconnect the hard-drive cable from the system board.
Lift the hard-drive assembly off the palm-rest assembly.
Disconnect the interposer from the hard-drive assembly.
Remove the screws that secure the hard-drive bracket to the hard drive.
Lift the hard drive off the hard-drive bracket.
To reassemble your device, follow these instructions in reverse order with the replacement hard drive.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
