Zum Hauptinhalt wechseln
Dell XPS 15 9530 Screen Replacement
Was du brauchst
  1. Dell XPS 15 9530 Screen Replacement, Base Cover: Schritt 1, Bild 1 von 3 Dell XPS 15 9530 Screen Replacement, Base Cover: Schritt 1, Bild 2 von 3 Dell XPS 15 9530 Screen Replacement, Base Cover: Schritt 1, Bild 3 von 3
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 Screen Replacement: Schritt 2, Bild 1 von 2 Dell XPS 15 9530 Screen Replacement: Schritt 2, Bild 2 von 2
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 Screen Replacement: Schritt 3, Bild 1 von 1
    • Lift the lower case off.
  4. Dell XPS 15 9530 Screen Replacement, Battery: Schritt 4, Bild 1 von 2 Dell XPS 15 9530 Screen Replacement, Battery: Schritt 4, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  5. Dell XPS 15 9530 Screen Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  6. Dell XPS 15 9530 Screen Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery off the chassis.
  7. Dell XPS 15 9530 Screen Replacement, SSD: Schritt 7, Bild 1 von 1
    • Pull lift tabs and remove the plastic that covers the hard drive to expose the hard drive.
  8. Dell XPS 15 9530 Screen Replacement: Schritt 8, Bild 1 von 2 Dell XPS 15 9530 Screen Replacement: Schritt 8, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove two 2.5mm screws that secure the SSD to the chassis.
  9. Dell XPS 15 9530 Screen Replacement: Schritt 9, Bild 1 von 1
    • Pull the SSD out parallel to the mainboard.
  10. Dell XPS 15 9530 Screen Replacement, Screen: Schritt 10, Bild 1 von 2 Dell XPS 15 9530 Screen Replacement, Screen: Schritt 10, Bild 2 von 2
    • Unplug the screen connector.
  11. Dell XPS 15 9530 Screen Replacement: Schritt 11, Bild 1 von 2 Dell XPS 15 9530 Screen Replacement: Schritt 11, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the four 4mm screws holding in the screen hinges.
  12. Dell XPS 15 9530 Screen Replacement: Schritt 12, Bild 1 von 1
    • Pull chassis away from screen assembly.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 34
Insgesamt: 2,138
