Einleitung
This guide walks through the replacement of the keyboard in a Dell XPS laptop. It also includes instructions to remove of all the components necessary to access the keyboard.
Make sure to have a safe location to store all of the small screws while completing this guide, as the screws are very small and easy to lose.
Was du brauchst
Turn the laptop upside down.
Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
Open up the information panel door (on the middle of the back side).
While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
There are 2 separate RAM sticks.
Gently push down on the 2 outside tabs of the RAM stick you want to replace.
While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
With a Philips #00 Screwdriver bit, remove one 4 mm long black screw located by the antenna connections on the wireless card.
Set the screw and metal holder aside.
Gently lift up each of the antennas (3) to disconnect them from the wireless card.
With the antennas disconnected, gently pull the wireless card out at the angle it sits at.
The wireless card has been successfully removed!
Use the Small Plastic Spudger to carefully disconnect the white connector from the black port.
Use the Phillips #00 Screwdriver to remove the two 4 mm long screws.
The left fan screw locations are circled in red.
The right fan screw locations are circled in orange.
Use a Philips #00 Screwdriver to remove the seven 3 mm long screws from the perimeter of the battery.
Firmly grasp the black connector on both sides.
Carefully pull the connector towards the battery, to release the connector and the battery from the laptop.
The touchpad has two ZIF connectors at the bottom of the motherboard. Use a flat plastic tool to lift the tabs (see picture 2) and gently pull the ribbon cables free.
Remove the single Phillips screw to take off this plate and reveal the connector underneath.
Pull up the black strap with the plastic spudger, and use your fingers to gently but firmly pull straight up.
Pull up on the plastic edges to remove the indicated connector at the bottom right of the motherboard.
This connector in the top left might be taped in two places. Simply pull up to loosen the tape, and use the plastic edges of the connector to pull it out. Have some tape on hand for reassembly, as the tape might have lost its adhesive backing.
With all mounted components removed, unscrew the motherboard Phillips-head screws.
Remove the 14 #00 Phillips screws from the perimeter of the keyboard.
Use small tweezers to peel back the covers for the remaining 9 #00 Phillips screws.
Remove the remaining screws.
Unplug the keyboard from the laptop by flipping up the small ZIF tabs and pulling the ribbon cables straight out.
Now you have successfully removed your keyboard. To reassemble your device, follow these instructions in reverse order.
5 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
Will this work with a Dell Precision 5520? I have noticed that these two laptops use many of the same components.
This was an excellent guide! The entire process took me a full two hours. Most of the time was spent trying to figure out how to fix a broken antenna filament on the wifi card. See my note regarding that step. My daughter's laptop keyboard is now brand new and I was able to remove all the dog hair and dust at the same time!
This was super-helpful. I have an XPS 7590, and a few things were slightly different, but this guide matched my machine closely enough. I now have a fully working machine with a new keyboard. Thanks!
wonderfully written & diagrammed guide, thank you internet friend!
