Einleitung
Motherboards are usually the last thing to check if something isn't working, unless you have a specific diagnosis. For this laptop, there are chipsets attached to the motherboard, so if you have a damaged CPU or GPU, you will likely have to replace the whole unit.
Thankfully, this device's construction is not super complicated and you should be able to easily complete this repair. Take extra care to keep each step's screws separated, as there are many different components to remove before you can access the motherboard.
Was du brauchst
Turn the laptop upside down.
Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
Open up the information panel door (on the middle of the back side).
While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
There are 2 separate RAM sticks.
Gently push down on the 2 outside tabs of the RAM stick you want to replace.
While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
With a Philips #00 Screwdriver bit, remove one 4 mm long black screw located by the antenna connections on the wireless card.
Set the screw and metal holder aside.
Gently lift up each of the antennas (3) to disconnect them from the wireless card.
With the antennas disconnected, gently pull the wireless card out at the angle it sits at.
The wireless card has been successfully removed!
Use the Small Plastic Spudger to carefully disconnect the white connector from the black port.
Use the Phillips #00 Screwdriver to remove the two 4 mm long screws.
The left fan screw locations are circled in red.
The right fan screw locations are circled in orange.
Use a Philips #00 Screwdriver to remove the seven 3 mm long screws from the perimeter of the battery.
Firmly grasp the black connector on both sides.
Carefully pull the connector towards the battery, to release the connector and the battery from the laptop.
The touchpad has two ZIF connectors at the bottom of the motherboard. Use a flat plastic tool to lift the tabs (see picture 2) and gently pull the ribbon cables free.
Remove the single Phillips screw to take off this plate and reveal the connector underneath.
Pull up the black strap with the plastic spudger, and use your fingers to gently but firmly pull straight up.
Pull up on the plastic edges to remove the indicated connector at the bottom right of the motherboard.
This connector in the top left might be taped in two places. Simply pull up to loosen the tape, and use the plastic edges of the connector to pull it out. Have some tape on hand for reassembly, as the tape might have lost its adhesive backing.
With all mounted components removed, unscrew the motherboard Phillips-head screws.
