Einleitung
The may need to be replaced if you are running out of storage space, or if you have saved files being corrupted. If the battery works but the computer will not boot up, it may be the SSD. On the Dell XPS 15 9550, it is easily accessible after the back panel is removed.
Was du brauchst
Turn the laptop upside down.
Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
Open up the information panel door (on the middle of the back side).
While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
Eine weitere Person hat diese Anleitung absolviert.
