Einleitung
Use this guide to learn the steps to remove the base cover of your Dell XPS 15 9570. The base cover must be removed to see inside the device.
Prior to starting this guide, be sure the laptop is powered off and it is unplugged from the charging cord.
Was du brauchst
Flip the device over so the base cover of the computer is facing upwards.
Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
