Einleitung
This guide will show you how to replace the RAM in a Dell XPS 15 9570 laptop. RAM allows applications and processes to store short-term memory and helps to optimize your computer's performance. This step-by-step guide will show you how to replace the RAM in a very easy manner. Be safe with your computer and happy fixing!
Was du brauchst
Flip the device over so the base cover of the computer is facing upwards.
Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
