Zum Hauptinhalt wechseln
Dell XPS 15 9570 Speaker Replacement
Was du brauchst
  1. Dell XPS 15 9570 Speaker Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Speaker Replacement: Schritt 2, Bild 1 von 3 Dell XPS 15 9570 Speaker Replacement: Schritt 2, Bild 2 von 3 Dell XPS 15 9570 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Speaker Replacement: Schritt 3, Bild 1 von 2 Dell XPS 15 9570 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Speaker Replacement, Battery: Schritt 5, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Speaker Replacement: Schritt 7, Bild 1 von 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Speaker Replacement, Speaker: Schritt 8, Bild 1 von 2 Dell XPS 15 9570 Speaker Replacement, Speaker: Schritt 8, Bild 2 von 2
    • Using the iFixit opening tool, disconnect the speaker cable by pulling it out gently.
  9. Dell XPS 15 9570 Speaker Replacement: Schritt 9, Bild 1 von 3 Dell XPS 15 9570 Speaker Replacement: Schritt 9, Bild 2 von 3 Dell XPS 15 9570 Speaker Replacement: Schritt 9, Bild 3 von 3
    • Remove the four 2mm screws using the Phillips #00 screwdriver.
    • There are two on the left speaker and two on the right.
    • Follow the images for the right side to complete the left side as well.
  10. Dell XPS 15 9570 Speaker Replacement: Schritt 10, Bild 1 von 1
    • Remove the speakers from the back of the computer.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
University of Alabama, Team 2-4, Bedsole Fall 2021 Mitglied von University of Alabama, Team 2-4, Bedsole Fall 2021
UA-BEDSOLE-F21S2G4
3 Mitglieder
18 Anleitungen geschrieben
Ein Kommentar
Thank you for the tutorial!
Just did the swap with speakers form a DELL XPS 15 from an unknown model (most likely wasn't a 9570). Note that these speakers are common inbetween different XPS 15 models (at least XPS 9550 9560 M5510 9350 5520 5510 and Precision 5510 5520 5530 5540 PK23000RP00 TX47W 0TX47W) ******and can be interchanged.
The ones I just used were salvaged from an out-of-service XPS 15 but the parts can be sourced online easily (ex: https://www.amazon.com/Deal4GO-Speaker-R... )
Cheers
Antalog - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 67
Insgesamt: 1,908
