Zum Hauptinhalt wechseln
Dell XPS 15 9570 Wireless Card Replacement
Was du brauchst
  1. Dell XPS 15 9570 Wireless Card Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Wireless Card Replacement: Schritt 2, Bild 1 von 3 Dell XPS 15 9570 Wireless Card Replacement: Schritt 2, Bild 2 von 3 Dell XPS 15 9570 Wireless Card Replacement: Schritt 2, Bild 3 von 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Wireless Card Replacement: Schritt 3, Bild 1 von 2 Dell XPS 15 9570 Wireless Card Replacement: Schritt 3, Bild 2 von 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Wireless Card Replacement: Schritt 4, Bild 1 von 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: Schritt 5, Bild 1 von 2 Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: Schritt 5, Bild 2 von 2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  6. Dell XPS 15 9570 Wireless Card Replacement: Schritt 6, Bild 1 von 1
    • Lift the wireless card bracket off of the wireless card.
  7. Dell XPS 15 9570 Wireless Card Replacement: Schritt 7, Bild 1 von 2 Dell XPS 15 9570 Wireless Card Replacement: Schritt 7, Bild 2 von 2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  8. Dell XPS 15 9570 Wireless Card Replacement: Schritt 8, Bild 1 von 1
    • Carefully remove the wireless card.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
University of Alabama, Team 2-4, Bedsole Fall 2021 Mitglied von University of Alabama, Team 2-4, Bedsole Fall 2021
UA-BEDSOLE-F21S2G4
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 48
Insgesamt: 2,716
