Zum Hauptinhalt wechseln
Dell XPS 15 9575 Fan Replacement
Was du brauchst
  1. Dell XPS 15 9575 Fan Replacement, Bottom Cover: Schritt 1, Bild 1 von 3 Dell XPS 15 9575 Fan Replacement, Bottom Cover: Schritt 1, Bild 2 von 3 Dell XPS 15 9575 Fan Replacement, Bottom Cover: Schritt 1, Bild 3 von 3
    • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
    • Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
    • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  2. Dell XPS 15 9575 Fan Replacement: Schritt 2, Bild 1 von 1
    • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Remove the bottom cover from the device when all sides are free.
  3. Dell XPS 15 9575 Fan Replacement, Interconnect Cable: Schritt 3, Bild 1 von 2 Dell XPS 15 9575 Fan Replacement, Interconnect Cable: Schritt 3, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove all four silver 3.2 mm screws fastening the interconnect cable.
  4. Dell XPS 15 9575 Fan Replacement: Schritt 4, Bild 1 von 2 Dell XPS 15 9575 Fan Replacement: Schritt 4, Bild 2 von 2
    • Carefully wedge the plastic opening pick between the fan and the interconnect cable.
    • If this position does not release the interconnect cable, slide the opening pick along the edge until it is completely free.
    • Remove the interconnect cable.
  5. Dell XPS 15 9575 Fan Replacement: Schritt 5, Bild 1 von 2 Dell XPS 15 9575 Fan Replacement: Schritt 5, Bild 2 von 2
    • Use the nylon tweezers to remove the interconnect pins from each of the circuit boards.
  6. Dell XPS 15 9575 Fan Replacement, Fan: Schritt 6, Bild 1 von 2 Dell XPS 15 9575 Fan Replacement, Fan: Schritt 6, Bild 2 von 2
    • Use the Phillips 0 Screwdriver to carefully extract each of the four 3.2 mm screws.
  7. Dell XPS 15 9575 Fan Replacement: Schritt 7, Bild 1 von 2 Dell XPS 15 9575 Fan Replacement: Schritt 7, Bild 2 von 2
    • Confirm all four screws have been extracted from the fan.
    • Find the wire connecting the fan into the motherboard and use the plastic opening tool to push the wire out from the motherboard's port.
  8. Dell XPS 15 9575 Fan Replacement: Schritt 8, Bild 1 von 2 Dell XPS 15 9575 Fan Replacement: Schritt 8, Bild 2 von 2
    • The fan has been completely disconnected and is now safe to remove.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 24
Insgesamt: 1,563
