Zum Hauptinhalt wechseln
Dell XPS 15 9575 Trackpad Replacement
Was du brauchst
  1. Dell XPS 15 9575 Trackpad Replacement, Bottom Cover: Schritt 1, Bild 1 von 3 Dell XPS 15 9575 Trackpad Replacement, Bottom Cover: Schritt 1, Bild 2 von 3 Dell XPS 15 9575 Trackpad Replacement, Bottom Cover: Schritt 1, Bild 3 von 3
    • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
    • Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
    • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  2. Dell XPS 15 9575 Trackpad Replacement: Schritt 2, Bild 1 von 1
    • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Remove the bottom cover from the device when all sides are free.
  3. Dell XPS 15 9575 Trackpad Replacement, Interconnect Cable: Schritt 3, Bild 1 von 2 Dell XPS 15 9575 Trackpad Replacement, Interconnect Cable: Schritt 3, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove all four silver 3.2 mm screws fastening the interconnect cable.
  4. Dell XPS 15 9575 Trackpad Replacement: Schritt 4, Bild 1 von 2 Dell XPS 15 9575 Trackpad Replacement: Schritt 4, Bild 2 von 2
    • Carefully wedge the plastic opening pick between the fan and the interconnect cable.
    • If this position does not release the interconnect cable, slide the opening pick along the edge until it is completely free.
    • Remove the interconnect cable.
  5. Dell XPS 15 9575 Trackpad Replacement: Schritt 5, Bild 1 von 2 Dell XPS 15 9575 Trackpad Replacement: Schritt 5, Bild 2 von 2
    • Use the nylon tweezers to remove the interconnect pins from each of the circuit boards.
  6. Dell XPS 15 9575 Trackpad Replacement, Battery: Schritt 6, Bild 1 von 2 Dell XPS 15 9575 Trackpad Replacement, Battery: Schritt 6, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove all eight 6.4 mm screws from the battery.
  7. Dell XPS 15 9575 Trackpad Replacement: Schritt 7, Bild 1 von 2 Dell XPS 15 9575 Trackpad Replacement: Schritt 7, Bild 2 von 2
    • Use a plastic opening pick to pry the black battery cable away from its silver adapter.
    • Hold the pick at 35 degrees from the computer and push towards the battery to remove the cable from its socket.
    • Do not push straight into the battery cable as this could damage the adapter.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  8. Dell XPS 15 9575 Trackpad Replacement: Schritt 8, Bild 1 von 2 Dell XPS 15 9575 Trackpad Replacement: Schritt 8, Bild 2 von 2
    • Use a plastic opening pick to separate the battery from the device.
    • Lift the battery straight up and remove it when it is completely separated.
  9. Dell XPS 15 9575 Trackpad Replacement, Trackpad: Schritt 9, Bild 1 von 2 Dell XPS 15 9575 Trackpad Replacement, Trackpad: Schritt 9, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the two silver 3.2mm screws located in the two top corners of the trackpad.
    • The screws may have a black cover on them.
  10. Dell XPS 15 9575 Trackpad Replacement: Schritt 10, Bild 1 von 3 Dell XPS 15 9575 Trackpad Replacement: Schritt 10, Bild 2 von 3 Dell XPS 15 9575 Trackpad Replacement: Schritt 10, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Flip the locking tab of the trackpad ZIF connector upwards with an opening pick, allowing the ribbon strip to be pulled forward.
    • Gently remove the ribbon cable with a set of tweezers.
  11. Dell XPS 15 9575 Trackpad Replacement: Schritt 11, Bild 1 von 2 Dell XPS 15 9575 Trackpad Replacement: Schritt 11, Bild 2 von 2
    • Open the laptop slightly and place your hand underneath the trackpad, gently popping the trackpad up from the case.
    • Once the trackpad is popped up, slide it outwards in order to remove it from the holder.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 29
Insgesamt: 3,147
