Einleitung
This guide will help you replace the Wifi card on your Dell XPS. The Wifi card is known to fail in the Dell XPS, so this easy repair should fix that. This guide will only require you to remove one screw, and pull the Wifi Card out of place.
Was du brauchst
Find and remove the two .3cm torx head screws using a T5 screwdriver.
Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
Find the .3cm Phillips head screw holding the WiFi Card in place and remove it.
