Zum Hauptinhalt wechseln
Dell XPS 15-L502X Hard Drive Replacement
Was du brauchst
  1. Dell XPS 15-L502X Hard Drive Replacement, Front Cover: Schritt 1, Bild 1 von 1
    • Before prying up on the cover, you may have to first remove a screw located inside the battery compartment (M2X3) and release the two latches. If you don't release the latches, you may snap the cover.
    • Pry up the top of the cover first by using a spudger to wedge in between the cover and base of the computer.
    • Once the spudger is between the cover and the base of the computer, wedge underneath the remaining border surrounding the keyboard.
    • Cracking sounds are normal. Be careful and take your time removing this panel.
  2. Dell XPS 15-L502X Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Work your fingers underneath the cover. Then, delicately pull the cover off of the computer.
    • The mouse pad is connected to the rest of the computer via two cables underneath the cover. These cables must be unhooked before the cover can be completely removed.
  3. Dell XPS 15-L502X Hard Drive Replacement: Schritt 3, Bild 1 von 2 Dell XPS 15-L502X Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Unhook the cables connected to the mouse pad by flipping up the black tabs that hold either cable in place.
    • Releasing these cables can be done by hand or by using a spudger.
  4. Dell XPS 15-L502X Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Slide the Hard Drive away from the mouse pad to disconnect/unplug it.
  5. Dell XPS 15-L502X Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Pull the tab up and out to remove the Hard Drive.
Abschluss
12 weitere Personen haben diese Anleitung absolviert.
Vishal
778 Reputation
6 Anleitungen geschrieben
IUPUI, Team 2-3, Baechle Fall 2015 Mitglied von IUPUI, Team 2-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G3
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 34
Letzte 30 Tage: 88
Insgesamt: 13,353
