Zum Hauptinhalt wechseln
Dell XPS 17 L702X Hard Drive Replacement
Was du brauchst
  1. Dell XPS 17 L702X Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Hard Drive Replacement: Schritt 2, Bild 1 von 2 Dell XPS 17 L702X Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Hard Drive Replacement: Schritt 3, Bild 1 von 2 Dell XPS 17 L702X Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Hard Drive Replacement: Schritt 5, Bild 1 von 3 Dell XPS 17 L702X Hard Drive Replacement: Schritt 5, Bild 2 von 3 Dell XPS 17 L702X Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Hard Drive Replacement: Schritt 6, Bild 1 von 2 Dell XPS 17 L702X Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Hard Drive Replacement: Schritt 7, Bild 1 von 3 Dell XPS 17 L702X Hard Drive Replacement: Schritt 7, Bild 2 von 3 Dell XPS 17 L702X Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Hard Drive Replacement: Schritt 9, Bild 1 von 2 Dell XPS 17 L702X Hard Drive Replacement: Schritt 9, Bild 2 von 2
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Hard Drive Replacement: Schritt 10, Bild 1 von 3 Dell XPS 17 L702X Hard Drive Replacement: Schritt 10, Bild 2 von 3 Dell XPS 17 L702X Hard Drive Replacement: Schritt 10, Bild 3 von 3
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Hard Drive Replacement: Schritt 11, Bild 1 von 2 Dell XPS 17 L702X Hard Drive Replacement: Schritt 11, Bild 2 von 2
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Hard Drive Replacement: Schritt 12, Bild 1 von 1
    • Remove the hard drive casing.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Shin Sul
544 Reputation
3 Anleitungen geschrieben
CSU Fullerton, Team 2-6, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 2-6, Bruce Fall 2015
CSUF-BRUCE-F15S2G6
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 4,341
