Zum Hauptinhalt wechseln
Dell XPS 17 L702X Motherboard Replacement
Was du brauchst
  1. Dell XPS 17 L702X Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Motherboard Replacement: Schritt 2, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Motherboard Replacement: Schritt 3, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 3, Bild 2 von 2
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Motherboard Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Motherboard Replacement: Schritt 5, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 5, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Motherboard Replacement: Schritt 6, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Motherboard Replacement: Schritt 7, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 7, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Motherboard Replacement: Schritt 9, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Motherboard Replacement: Schritt 10, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 10, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Motherboard Replacement: Schritt 11, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Remove the hard drive casing.
  13. Dell XPS 17 L702X Motherboard Replacement, Palm Rest: Schritt 13, Bild 1 von 1
    • Unscrew the screw holding the optical drive with a Phillips screwdriver.
  14. Dell XPS 17 L702X Motherboard Replacement: Schritt 14, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 14, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 14, Bild 3 von 3
    • Using a plastic opening tool, pull out the optical drive.
  15. Dell XPS 17 L702X Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
  16. Dell XPS 17 L702X Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
  17. Dell XPS 17 L702X Motherboard Replacement: Schritt 17, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 17, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 17, Bild 3 von 3
    • Push and hold the tab inside the optical drive's opening with your index finger.
    • Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
  18. Dell XPS 17 L702X Motherboard Replacement: Schritt 18, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 18, Bild 2 von 2
    • Slide the spudger around the palm rest to release the clips.
    • You may hear a crackling noise; this is normal.
    • Use caution when sliding below the mouse pad, as there are wires we must detach in the next steps.
  19. Dell XPS 17 L702X Motherboard Replacement: Schritt 19, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 19, Bild 2 von 2
    • Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
    • The mouse pad wires are still connected to the palm rest panel.
  20. Dell XPS 17 L702X Motherboard Replacement: Schritt 20, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 20, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 20, Bild 3 von 3
    • Put the spudger below the black tab of the wider cable and push up to release.
    • Gently pull out the cable.
  21. Dell XPS 17 L702X Motherboard Replacement: Schritt 21, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 21, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 21, Bild 3 von 3
    • Insert the spudger below the black tab of the remaining cable and push up to release.
  22. Dell XPS 17 L702X Motherboard Replacement: Schritt 22, Bild 1 von 1
    • Remove the palm rest from the laptop.
  23. Dell XPS 17 L702X Motherboard Replacement, Keyboard: Schritt 23, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement, Keyboard: Schritt 23, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement, Keyboard: Schritt 23, Bild 3 von 3
    • Using the plastic opening tool, slightly lift and rotate the keyboard until it's upside down from the display side of the laptop.
    • DO NOT lift the keyboard all the way up as there are wires that are still connected.
  24. Dell XPS 17 L702X Motherboard Replacement: Schritt 24, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 24, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 24, Bild 3 von 3
    • Gently insert the spudger below the edge of the black tab of the thin, copper colored cable and pry it open.
  25. Dell XPS 17 L702X Motherboard Replacement: Schritt 25, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 25, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 25, Bild 3 von 3
    • Gently insert the spudger under the edge of the black tab of the cable marked "UP" and pry it open.
  26. Dell XPS 17 L702X Motherboard Replacement: Schritt 26, Bild 1 von 1
    • Remove the keyboard from the laptop.
  27. Dell XPS 17 L702X Motherboard Replacement, Display: Schritt 27, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement, Display: Schritt 27, Bild 2 von 2
    • Close the display, and flip the laptop over so that the bottom faces upwards.
    • Remove the two 16 mm screws with a Phillips screwdriver.
  28. Dell XPS 17 L702X Motherboard Replacement: Schritt 28, Bild 1 von 1
    • Gently flip over the laptop and open the back cover assembly.
  29. Dell XPS 17 L702X Motherboard Replacement: Schritt 29, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 29, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 29, Bild 3 von 3
    • Insert the pointy side of the spudger below the golden connector of the white cable on the WLAN card and lift to detach.
  30. Dell XPS 17 L702X Motherboard Replacement: Schritt 30, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 30, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 30, Bild 3 von 3
    • Unscrew the 4mm screw from the WLAN card with a Phillips screwdriver. The card will lift itself after you remove the 4mm screw.
    • Gently pull out the WLAN card.
  31. Dell XPS 17 L702X Motherboard Replacement: Schritt 31, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 31, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 31, Bild 3 von 3
    • Insert the pointy side of the spudger below the golden color connector of the gray cable on the WWAN card and lift to detach.
    • Insert the pointy side of the spudger below the golden color connector of the black cable on the WWAN card and lift to detach.
  32. Dell XPS 17 L702X Motherboard Replacement: Schritt 32, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 32, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 32, Bild 3 von 3
    • Unscrew the 4mm screw from the WWAN card with a Phillips screwdriver. The card will lift itself.
    • Gently pull out the WWAN card.
  33. Dell XPS 17 L702X Motherboard Replacement: Schritt 33, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 33, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 33, Bild 3 von 3
    • Gently remove the wires for the WLAN and WWAN cards from their housing.
  34. Dell XPS 17 L702X Motherboard Replacement: Schritt 34, Bild 1 von 1
    • Unscrew four the 8mm screws directly under the keyboard with a Phillips screwdriver.
  35. Dell XPS 17 L702X Motherboard Replacement: Schritt 35, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 35, Bild 2 von 2
    • Loosen the grounding screw attached to the black monitor cable with a Phillips screwdriver.
    • DO NOT ATTEMPT TO REMOVE THE SCREW FROM THE WIRE. The screw is permanently fixed onto the wire.
  36. Dell XPS 17 L702X Motherboard Replacement: Schritt 36, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 36, Bild 2 von 2
    • Using the plastic opening tool, detach the connection from the cable to the board.
  37. Dell XPS 17 L702X Motherboard Replacement: Schritt 37, Bild 1 von 1
    • Gently remove the monitor cable from its holdings from the board.
  38. Dell XPS 17 L702X Motherboard Replacement: Schritt 38, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 38, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 38, Bild 3 von 3
    • Hold the plastic edge of the display firmly and lift to remove the display.
  39. Dell XPS 17 L702X Motherboard Replacement, Motherboard: Schritt 39, Bild 1 von 1
    • Unscrew the ten 8mm screws from the grey inner casing with a Phillips screwdriver.
  40. Dell XPS 17 L702X Motherboard Replacement: Schritt 40, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 40, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 40, Bild 3 von 3
    • Locate the sound card cable.
    • Gently unplug the sound card cable.
  41. Dell XPS 17 L702X Motherboard Replacement: Schritt 41, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 41, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 41, Bild 3 von 3
    • Find the orange cable with the letters MB.
    • Gently insert the spudger below the edge of the black tab and pry it open.
    • DO NOT attempt to pull out the cable on this step.
  42. Dell XPS 17 L702X Motherboard Replacement: Schritt 42, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 42, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 42, Bild 3 von 3
    • Locate the wire on the side of WWAN slot.
    • Using the spudger, gently pull out the cable.
  43. Dell XPS 17 L702X Motherboard Replacement: Schritt 43, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 43, Bild 2 von 2
    • Gently flip the laptop with its bottom facing you.
    • Remove the four 8mm screws with a Phillips screwdriver.
    • Remove the two 16mm battery casing screws with a Phillips screwdriver.
    • Remove the two 16mm corner screws with a Phillips screwdriver.
    • Remove the two 4mm screws inside battery housing with a Phillips screwdriver.
    • Removing the RAM is optional. This guide does not cover the removal of the RAM card.
  44. Dell XPS 17 L702X Motherboard Replacement: Schritt 44, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 44, Bild 2 von 2
    • Holding the opening from the optical drive in one hand with the other hand holding the opposite side of the laptop, lift and remove the back cover assembly.
  45. Dell XPS 17 L702X Motherboard Replacement: Schritt 45, Bild 1 von 1
    • Unscrew the seven 4mm screws with a Phillips screwdriver.
  46. Dell XPS 17 L702X Motherboard Replacement: Schritt 46, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 46, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 46, Bild 3 von 3
    • Unscrew the 6mm screw on the DC cable assembly with a Phillips screwdriver.
    • Lift the DC cable assembly out of the casing.
    • Gently unplug the DC cable.
  47. Dell XPS 17 L702X Motherboard Replacement: Schritt 47, Bild 1 von 1
    • Lift and remove the Wi-Fi circuit board.
  48. Dell XPS 17 L702X Motherboard Replacement: Schritt 48, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 48, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 48, Bild 3 von 3
    • Gently use a spudger to pry off the fan power cable.
    • Lift and remove the fan.
  49. Dell XPS 17 L702X Motherboard Replacement: Schritt 49, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 49, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 49, Bild 3 von 3
    • Lift and remove the USB circuit board out of its housing.
    • Remove the orange cable from the motherboard by gently pulling away from the connection point.
  50. Dell XPS 17 L702X Motherboard Replacement: Schritt 50, Bild 1 von 2 Dell XPS 17 L702X Motherboard Replacement: Schritt 50, Bild 2 von 2
    • Loosen the six screws with a Phillips screwdriver.
    • The screws are attached to the heat sink piece. Do not attempt to remove them from the heat sink assembly.
  51. Dell XPS 17 L702X Motherboard Replacement: Schritt 51, Bild 1 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 51, Bild 2 von 3 Dell XPS 17 L702X Motherboard Replacement: Schritt 51, Bild 3 von 3
    • Gently lift and remove the motherboard.
    • Clean the thermal paste with rubbing alcohol and a microfiber cloth or non-abrasive tissue.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Eddie
455 Reputation
2 Anleitungen geschrieben
CSU Fullerton, Team 2-6, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 2-6, Bruce Fall 2015
CSUF-BRUCE-F15S2G6
4 Mitglieder
8 Anleitungen geschrieben
4 Kommentare
it really helped me out with my extremely fast overheating pc. and now it is mutch cooler and working great, Thanks!
Bjorn stevens - Antwort
I wouldn’t rate this as extremely difficult though to be honest. I’d say moderate at best.
Clems - Antwort
Great step by step guide with excellent photos helped me to reapply Thermal paste to my CPU/GPU heatsink.
Thank you!
Petros Lamprakis - Antwort
Not difficult at all to dismantle this thing. I do it all the time for maintenance.
80s Guy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 20
Letzte 30 Tage: 50
Insgesamt: 6,683
