Einleitung
This guide is used as a prerequisite for replacing internal parts in the Dell XPS 18
Was du brauchst
Turn the device on its screen.
Remove the ten 4mm screws using a T8 Torx screwdriver.
Gently lift the back cover off the device. The back cover should come off easily.
Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
Remove the internal cover.
