Einleitung
This guide will show you how to properly remove and replace the left or right speaker of your Dell XPS 18.
Was du brauchst
Turn the device on its screen.
Remove the ten 4mm screws using a T8 Torx screwdriver.
Gently lift the back cover off the device. The back cover should come off easily.
Use the plastic opening tool's angled edge to lift the clasp securing the copper colored volume control cable.
Disconnect the volume control cable and pull it back.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
