Zum Hauptinhalt wechseln
Dell XPS 18 Left and Right Speakers Replacement
Was du brauchst
  1. Dell XPS 18 Left and Right Speakers Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Left and Right Speakers Replacement: Schritt 2, Bild 1 von 1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Left and Right Speakers Replacement: Schritt 3, Bild 1 von 1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: Schritt 4, Bild 1 von 2 Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool's angled edge to lift the clasp securing the copper colored volume control cable.
    • Disconnect the volume control cable and pull it back.
  5. Dell XPS 18 Left and Right Speakers Replacement: Schritt 5, Bild 1 von 1
    • Firmly pull the blue speaker cable loose.
  6. Dell XPS 18 Left and Right Speakers Replacement: Schritt 6, Bild 1 von 1
    • Remove the two black 4mm screws with a Phillips 00 screwdriver.
  7. Dell XPS 18 Left and Right Speakers Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the speaker.
    • To remove the right speaker, follow these same steps.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Austin Weir
1.287 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 6-29, Amido Winter 2015 Mitglied von Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 17
Insgesamt: 1,238
