Zum Hauptinhalt wechseln
Dell XPS 18 Touch Control Board Replacement
Was du brauchst
  1. Dell XPS 18 Touch Control Board Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Touch Control Board Replacement: Schritt 2, Bild 1 von 1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Touch Control Board Replacement: Schritt 3, Bild 1 von 1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Touch Control Board Replacement, Internal Cover: Schritt 4, Bild 1 von 1
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Touch Control Board Replacement: Schritt 5, Bild 1 von 2 Dell XPS 18 Touch Control Board Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Touch Control Board Replacement: Schritt 6, Bild 1 von 2 Dell XPS 18 Touch Control Board Replacement: Schritt 6, Bild 2 von 2
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Touch Control Board Replacement, Touch Control Board: Schritt 7, Bild 1 von 2 Dell XPS 18 Touch Control Board Replacement, Touch Control Board: Schritt 7, Bild 2 von 2
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Touch Control Board Replacement: Schritt 8, Bild 1 von 2 Dell XPS 18 Touch Control Board Replacement: Schritt 8, Bild 2 von 2
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Touch Control Board Replacement: Schritt 9, Bild 1 von 2 Dell XPS 18 Touch Control Board Replacement: Schritt 9, Bild 2 von 2
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Austin Weir
1.287 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 6-29, Amido Winter 2015 Mitglied von Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Mitglieder
16 Anleitungen geschrieben
2 Kommentare
It worked perfectly. Thank you.
Kenneth Macdonald - Antwort
Which of Torx screwdrivers is used in step 1? As I can see, it is T8, but right above the Introduction section it is stated it is Torx T9...
Евгений Громов - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 1,895
