Zum Hauptinhalt wechseln
Dell XPS M1210 Fan Replacement
Was du brauchst
  1. Dell XPS M1210 Fan Replacement, Fan: Schritt 1, Bild 1 von 3 Dell XPS M1210 Fan Replacement, Fan: Schritt 1, Bild 2 von 3 Dell XPS M1210 Fan Replacement, Fan: Schritt 1, Bild 3 von 3
    • Before opening up your laptop make sure it is completely turned off and is not connected to the charger.
    • To prevent any damage to the system ,remove the main battery.
    • Turn the computer upside down and loosen the captive screw on the communications card cover.
    • Disconnect any antenna cables that are attached to the Mini-cards.
  2. Dell XPS M1210 Fan Replacement: Schritt 2, Bild 1 von 3 Dell XPS M1210 Fan Replacement: Schritt 2, Bild 2 von 3 Dell XPS M1210 Fan Replacement: Schritt 2, Bild 3 von 3
    • Open the display 180 degrees.
    • Insert a plastic scribe or a flat head screwdriver into the indent of the hinge cover on the right. Pry open the hinge cover.
    • Be gentle when prying open the hinge cover. Wiggle the cover left and right slowly lifting it up.
  3. Dell XPS M1210 Fan Replacement: Schritt 3, Bild 1 von 3 Dell XPS M1210 Fan Replacement: Schritt 3, Bild 2 von 3 Dell XPS M1210 Fan Replacement: Schritt 3, Bild 3 von 3
    • Remove the three Philips head screws at the top of the keyboard.
    • Lift the keyboard slightly up to disconnect the keyboard cable from the system board.
    • There will be a keyboard-connector pull-tab that will separate the keyboard from the laptop.
  4. Dell XPS M1210 Fan Replacement: Schritt 4, Bild 1 von 3 Dell XPS M1210 Fan Replacement: Schritt 4, Bild 2 von 3 Dell XPS M1210 Fan Replacement: Schritt 4, Bild 3 von 3
    • Use the pull-tab to disconnect the display cable from the system board.
    • Disconnect the display cable and the antenna cables from their cable channels.
    • Remove the four screws that connect the display to the computer base. There should be two on the bottom and two on the back of the computer labeled "D".
    • The display should then be disconnected from the rest of the laptop.
  5. Dell XPS M1210 Fan Replacement: Schritt 5, Bild 1 von 3 Dell XPS M1210 Fan Replacement: Schritt 5, Bild 2 von 3 Dell XPS M1210 Fan Replacement: Schritt 5, Bild 3 von 3
    • To remove the palm rest there will be seven screws labeled "P" that need to be removed.
    • Disconnect the coin-cell battery cable from the system board.
    • Then disconnect the touch-pad connector from the system board.
    • Turn the computer upside down. Loosen the captive screw, and remove the four screws from the bottom of the computer.
    • Lift the palm rest from the back of the computer to separate it.
  6. Dell XPS M1210 Fan Replacement: Schritt 6, Bild 1 von 3 Dell XPS M1210 Fan Replacement: Schritt 6, Bild 2 von 3 Dell XPS M1210 Fan Replacement: Schritt 6, Bild 3 von 3
    • Remove the screw from the fan, and then disconnect the fan cable from the system board.
Abschluss
To reassemble your device, secure the fan with the 4 screws, and reinstall the keyboard and hinge cover in reverse order of the above instructions.
Dave
226 Reputation
2 Anleitungen geschrieben
Penn State, Team 1-100, Kaschak Winter 2015 Mitglied von Penn State, Team 1-100, Kaschak Winter 2015
PSU-KASCHAK-W15S1G100
4 Mitglieder
2 Kommentare
Thanks for the explanation , was simply splendid.
Can you please share the part number of the Fan ? is it DELL XPS M1210 MCF-J10BM05 ?
tvshprakash - Antwort
Why do we need to remove the screen?
Louis Cox - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 1,440
