Zum Hauptinhalt wechseln
Dell XPS M1330 Fan Replacement
Was du brauchst
  1. Dell XPS M1330 Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop on its back, so that the underside is facing up.
  2. Dell XPS M1330 Fan Replacement: Schritt 2, Bild 1 von 1
    • Push and hold the slide button to the left and unlock the mechanism.
  3. Dell XPS M1330 Fan Replacement: Schritt 3, Bild 1 von 2 Dell XPS M1330 Fan Replacement: Schritt 3, Bild 2 von 2
    • Lift the computer up and slowly pull the battery straight out from the device.
  4. Dell XPS M1330 Fan Replacement, Fan: Schritt 4, Bild 1 von 2 Dell XPS M1330 Fan Replacement, Fan: Schritt 4, Bild 2 von 2
    • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
    • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
    • Remove the fan cover.
  5. Dell XPS M1330 Fan Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
    • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
  6. Dell XPS M1330 Fan Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Be sure to carefully remove the wires as they are fragile and can rip easily.
    • Remove the wire bay near the fan.
    • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
    • Gently pull upward while moving your hand side to side so the plastic holder will detach.
  7. Dell XPS M1330 Fan Replacement: Schritt 7, Bild 1 von 1
    • Gently remove the fan and its attachments from the bay.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kai Kapossy
676 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S6-G2, Peak Spring 2019 Mitglied von UMass Dartmouth, Team S6-G2, Peak Spring 2019
UMASSD-PEAK-S19S6G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 349
