Einleitung
If your keyboard is unresponsive due to interior damage from liquids or dirt, or has been physically damaged, then use this guide to replace it. You will need a Phillips head #01 Screwdriver, a Flathead 3.0 Screwdriver, an iFixit opening tool, and tweezers. This process is a little more difficult than the previous, but you will have no problems in using this guide.
Was du brauchst
Remove the four 5.0mm screws with a Phillips #1 screwdriver.
Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
Remove the fan cover.
Remove the four 0.1mm screws using the Phillips #1 screwdriver.
Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
Using the flathead screwdriver, turn the one screw counterclockwise to loosen the CPU, but do not remove the screw.
Unscrew the 5.0mm Phillips #1 screw from the wireless door cover.
Pull straight up on the wireless door.
Separate the two clips on both sides of the memory sticks.
The memory stick will lift up.
Gently pull the memory stick up and out of its holder.
Repeat these same steps for the second memory stick below.
Carefully open the screen, so it is facing toward yourself.
Flatten out the screen as much as possible.
Carefully lift the computer, so you can get a good grip by the hinges.
Carefully lift and remove the central control media button cover from the base.
Use the Phillips #1 screwdriver to remove the two 3.0mm screws at the top of the keyboard.
Gently pull the keyboard cable away from your body.
Detach the keyboard cable.
