Zum Hauptinhalt wechseln
Dell XPS M140 Screen Replacement
Was du brauchst
  1. Dell XPS M140 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • The first step is to turn over the laptop
  2. Dell XPS M140 Screen Replacement: Schritt 2, Bild 1 von 1
    • Locate the slide lock for the battery.
  3. Dell XPS M140 Screen Replacement: Schritt 3, Bild 1 von 2 Dell XPS M140 Screen Replacement: Schritt 3, Bild 2 von 2
    • Slide the lock and pull out the battery.
  4. Dell XPS M140 Screen Replacement, Screen: Schritt 4, Bild 1 von 3 Dell XPS M140 Screen Replacement, Screen: Schritt 4, Bild 2 von 3 Dell XPS M140 Screen Replacement, Screen: Schritt 4, Bild 3 von 3
    • On the plastic casing around the screen, there should be gray rubber circles lining the perimeter of the casing.
    • Remove these by peeling them off.
    • This will expose the screws underneath.
  5. Dell XPS M140 Screen Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the screws on the casing that you just exposed.
  6. Dell XPS M140 Screen Replacement: Schritt 6, Bild 1 von 3 Dell XPS M140 Screen Replacement: Schritt 6, Bild 2 von 3 Dell XPS M140 Screen Replacement: Schritt 6, Bild 3 von 3
    • Remove the casing.
    • This step requires care; the casing is secured with plastic clips that need to be popped off.
    • Run your hand, or a tool, around the perimeter, the casing should come off.
  7. Dell XPS M140 Screen Replacement: Schritt 7, Bild 1 von 3 Dell XPS M140 Screen Replacement: Schritt 7, Bild 2 von 3 Dell XPS M140 Screen Replacement: Schritt 7, Bild 3 von 3
    • Once the casing is removed, more screws should be exposed.
    • Remove every screw.
  8. Dell XPS M140 Screen Replacement: Schritt 8, Bild 1 von 3 Dell XPS M140 Screen Replacement: Schritt 8, Bild 2 von 3 Dell XPS M140 Screen Replacement: Schritt 8, Bild 3 von 3
    • Once all of the screws are removed, the screen should be loose.
    • Gently pick it up and place it face down onto the keyboard.
  9. Dell XPS M140 Screen Replacement: Schritt 9, Bild 1 von 3 Dell XPS M140 Screen Replacement: Schritt 9, Bild 2 von 3 Dell XPS M140 Screen Replacement: Schritt 9, Bild 3 von 3
    • There should be two connections.
    • One with a blue looking handle, and one with clips.
    • To remove the connection with the clips, squeeze the two clips together and pull the ribbon cable.
    • To remove the connection with the blue handle, gently pull on the blue handle, it should come right off.
Abschluss
UMass Dartmouth, Team S9-G5, Martin Spring 2017 Mitglied von UMass Dartmouth, Team S9-G5, Martin Spring 2017
UMASSD-MARTIN-S17S9G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 311
