Einleitung
The purpose of this guide is to remove the hard drive from the computer if it is broken or having issues. Some of the problems associated with a broken Hard Drive are that your computer is not booting up completely, some programs that were working are not recognized anymore, the Hard Drive is not recognized in the C: of "my computer", the computer tells you the drive is not recognized, or that the drive will fail.
Was du brauchst
Remove the four Phillips #1 screws holding the Hard Drive in place.
Four 3.5mm Phillips #1 screws
Pull the Hard Drive out gently using the tab. It should provide enough leverage to pull the drive out smoothly.
Remove both 3.5mm Phillips #1 screws on either side of the plastic casing.
Then gently separate the drive from its casing.
Eine weitere Person hat diese Anleitung absolviert.
