Zum Hauptinhalt wechseln
Dell XPS M1530 Hard Drive Replacement
Was du brauchst
  1. Dell XPS M1530 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Dell XPS M1530 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Dell XPS M1530 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Remove the four Phillips #1 screws holding the Hard Drive in place.
    • Four 3.5mm Phillips #1 screws
  5. Dell XPS M1530 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Dell XPS M1530 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Pull the Hard Drive out gently using the tab. It should provide enough leverage to pull the drive out smoothly.
  6. Dell XPS M1530 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Dell XPS M1530 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Remove both 3.5mm Phillips #1 screws on either side of the plastic casing.
    • There is a second screw on the other side of the casing.
    • Then gently separate the drive from its casing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Tyler Scholz
479 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 18-4, Maness Winter 2015 Mitglied von Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 2,023
