Zum Hauptinhalt wechseln
Dell XPS M1530 Wireless Card Replacement
Was du brauchst
  1. Dell XPS M1530 Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Wireless Card Replacement: Schritt 2, Bild 1 von 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Wireless Card Replacement: Schritt 3, Bild 1 von 2 Dell XPS M1530 Wireless Card Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Wireless Card Replacement, Wireless Card: Schritt 4, Bild 1 von 1
    • Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
    • Two 4.7mm Philips #1 screws
  5. Dell XPS M1530 Wireless Card Replacement: Schritt 5, Bild 1 von 2 Dell XPS M1530 Wireless Card Replacement: Schritt 5, Bild 2 von 2
    • Lift the panel up from the indented area.
    • This indent should provide enough grip to remove the panel with ease.
  6. Dell XPS M1530 Wireless Card Replacement: Schritt 6, Bild 1 von 1
    • Remove the single 3.9mm Phillips #1 screw in the upper right corner of the wireless card.
    • One 3.9mm Phillips #1 screw
  7. Dell XPS M1530 Wireless Card Replacement: Schritt 7, Bild 1 von 1
    • Lift the card out at an angle and carefully remove it.
  8. Dell XPS M1530 Wireless Card Replacement: Schritt 8, Bild 1 von 2 Dell XPS M1530 Wireless Card Replacement: Schritt 8, Bild 2 von 2
    • Use a spudger to carefully disconnect the antenna cables from the card by prying them straight up off the board.
    • It's best to use an ESD-safe tool, such as a nylon spudger, rather than the metal spudger shown in the photo.
    • Note the order of colors for the antenna cables indicated on the card.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jase Sasaki
721 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 18-4, Maness Winter 2015 Mitglied von Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,775
