Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Push the sliding button near the battery compartment.
    • Push the sliding button near the battery compartment.
  2. Slide the button next to the battery and lift up on the lip of the battery edge.
    • Slide the button next to the battery and lift up on the lip of the battery edge.
  3. Lift and remove the battery. Lift and remove the battery.
    • Lift and remove the battery.
  4. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  5. Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side. Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side. Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side.
    • Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side.
  6. Remove the four screws from the top of the keyboard bracket. Remove the four screws from the top of the keyboard bracket.
    • Remove the four screws from the top of the keyboard bracket.
  7. Remove the keyboard by sliding it forward, off of the clips, and then lifting up. Remove the keyboard by sliding it forward, off of the clips, and then lifting up. Remove the keyboard by sliding it forward, off of the clips, and then lifting up.
    • Remove the keyboard by sliding it forward, off of the clips, and then lifting up.
  8. Lift the keyboard about 2 inches up from the laptop platform. From this angle the keyboard ribbon connector can be seen and disconnected. From this angle the keyboard ribbon connector can be seen and disconnected.
    • Lift the keyboard about 2 inches up from the laptop platform.
    • From this angle the keyboard ribbon connector can be seen and disconnected.
Abschluss
Nikki Meyer
110 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 162
