Einleitung
Replace Memory
Was du brauchst
Turn the computer over, loosen the captive screws on the memory module cover, and then remove the cover.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Remove the module from the connector.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
