Einleitung
Before you begin the LCD Screen Display replacement process, be sure to ground yourself. Grounding yourself prevents short circuiting the device, and/or shocking yourself. An easy way to do so would be to remove one of your shoes.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Push the sliding button near the battery compartment.
    • Push the sliding button near the battery compartment.
  2. Slide the button next to the battery and lift up on the lip of the battery edge.
    • Slide the button next to the battery and lift up on the lip of the battery edge.
    • Lift and remove the battery.
    • Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side.
    • Remove the four screws from the top of the keyboard bracket.
    • Remove the keyboard by sliding it forward, off of the clips, and then lifting up.
    • Lift the keyboard about 2 inches up from the laptop platform.
    • From this angle the keyboard ribbon connector can be seen and disconnected.
    • Remove 2 M2x3mm screws that are located at the bottom of the plastic bezel with a PH0 screwdriver.
    • Use iFixit plastic tool and a cutout of cardboard to pry out the plastic bezel around the edges of the LCD screen
    • Disconnect the display connectors by removing them from the grooves and unplugging them.
    • Remove 12 M2x3mm screws along the edge of the screen frame with a PH0 screwdriver.
    • Disconnect the display connector behind the top of the screen.
Abschluss
Ethan Teel
Mitglied seit 13.02.2018
122 Reputation
1 Anleitung geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 114
