Einleitung
Is your input jack broken in your chromatic tuner? Instead of buying a new one you can just buy the input part itself and replace it. This method works for similar tuners but this guide is specifically for the DeltaLab CT-40 Chromatic Tuner.
Was du brauchst
First, open the metal stand to access the screws without damaging the body.
Snip the wires attached to the input jack port using the wire cutter as close to the input jack port as possible.
Take your new input jack port and solder the wires to the corresponding connection areas on the new port.
Learn how to solder (here).
Fold the wires back and put the new input port into the slot where it belongs on the tuner.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
