Zum Hauptinhalt wechseln
Denim Jeans Inner Thigh Replacement
Was du brauchst
  1. Denim Jeans Inner Thigh Replacement, Inner Thigh: Schritt 1, Bild 1 von 1
    • Use a simple back and forth pattern with the needle and thread to close the holes.
    • This step is to ensure the shape of your patch. It will not be the outright fix to the problem.
  2. Denim Jeans Inner Thigh Replacement: Schritt 2, Bild 1 von 3 Denim Jeans Inner Thigh Replacement: Schritt 2, Bild 2 von 3 Denim Jeans Inner Thigh Replacement: Schritt 2, Bild 3 von 3
    • Use an embroidery hoop as a stencil to trace out the damaged area.
    • Use fabric scissors to cut along the back panel of the jeans. Follow the line.
    • Cut only the back panel or you will have an unnecessary hole in the front of your pants.
  3. Denim Jeans Inner Thigh Replacement: Schritt 3, Bild 1 von 2 Denim Jeans Inner Thigh Replacement: Schritt 3, Bild 2 von 2
    • Place the cutouts in the denim swatch.
    • Trace a larger shape of the cutout.
    • Use fabric scissors to cut out the patches.
  4. Denim Jeans Inner Thigh Replacement: Schritt 4, Bild 1 von 3 Denim Jeans Inner Thigh Replacement: Schritt 4, Bild 2 von 3 Denim Jeans Inner Thigh Replacement: Schritt 4, Bild 3 von 3
    • Center the old denim onto the new patch.
    • Trace vertical and horizontal lines on denim by using a straight edge and some chalk.
    • Pin the old denim in place.
  5. Denim Jeans Inner Thigh Replacement: Schritt 5, Bild 1 von 1
    • Using an embroidery needle and an embroidery floss add stitches into the patch.
    • Use a Straight Stitch (just up and down sewing) following the vertical and then horizontal lines.
    • The embroidery floss comes as a twisted rope. You have to pull the threads from the rope before you can use them.
  6. Denim Jeans Inner Thigh Replacement: Schritt 6, Bild 1 von 1
    • Pin the patch with as little of the new patch showing as possible.
    • Use a Whip Stitch to attach the patch. This is an over/under sewing pattern.
    • Repeat a second time.
    • Turn inside out and trim down the patch. Use a straight stitch to tighten up any loose spots.
  7. Denim Jeans Inner Thigh Replacement, Finished: Schritt 7, Bild 1 von 1
    • The style is meant to look rustic and DIY. By no means is it a professional finish. Still functional and if done right can be quite cute!
Abschluss
This is a rustic or unfinished but functional looking patch for denim jeans.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 73
Insgesamt: 5,232
