Zum Hauptinhalt wechseln
  1. Clear large rocks from the streambed to make it easier to install the strut channel. Place cleared rocks downstream so they do not damage the node during a storm. Set 5 ft steel strut channel into place.
    • Clear large rocks from the streambed to make it easier to install the strut channel.
    • Place cleared rocks downstream so they do not damage the node during a storm.
    • Set 5 ft steel strut channel into place.
    • Ensure the open side of the strut channel faces south so that the solar panel receives maximum sunlight! Addtionally, be careful not to deform the steel strut channel too much. A bit of deformation is okay.
    • Use the post pounder to drive the strut channel 3 ft into the stream bed.
  2. Place two spring strut channel nuts into the strut channel and then place the strut channel connector. Two of the strut channel connector holes should be above the strut channel for connecting the top strut channel. Insert two washers and screws into  the nuts.
    • Place two spring strut channel nuts into the strut channel and then place the strut channel connector.
    • Two of the strut channel connector holes should be above the strut channel for connecting the top strut channel.
    • Insert two washers and screws into the nuts.
  3. This is what the attached strut channel connector looks like from above. Place two additional spring strut channel nuts into the aluminum strut channel to be attached. Insert the last two washers and screws into the nuts.
    • This is what the attached strut channel connector looks like from above.
    • Place two additional spring strut channel nuts into the aluminum strut channel to be attached.
    • Insert the last two washers and screws into the nuts.
    • Use an impact driver to secure the screws into place. The impact driver should have a 3/4 '' Socket connected via a socket adapter.
    • Socket Adapter
    • This is what the extended strut channel looks like.
  4. Line up a 1 ft strut channel with a u-bracket to the vertical strut channel. Put two spring strut channel nuts into the vertical strut channel. Insert two washers and screws into the u-bracket to hold the strut channel arm. Use the impact driver to tighten the screws.
    • Line up a 1 ft strut channel with a u-bracket to the vertical strut channel.
    • Put two spring strut channel nuts into the vertical strut channel. Insert two washers and screws into the u-bracket to hold the strut channel arm.
    • Use the impact driver to tighten the screws.
    • This is a what the final node holding structure looks like.
  5. Place two screws into the node enclosure with the 5/16'' washer and strut channel nuts on the backside. You can remove the strut channel nut spring to make installation easier. Slide the node into the strut channel arm.
    • Place two screws into the node enclosure with the 5/16'' washer and strut channel nuts on the backside.
    • You can remove the strut channel nut spring to make installation easier.
    • Slide the node into the strut channel arm.
    • The washer should be on the outside of the strut channel and the strut channel nut should be on the inside.
    • Tighten the screws with a 3/8 inch wrench.
  6. Create a 4 number lock combination.
    • Create a 4 number lock combination.
    • Projects have set lock combinations. Ask the lab for guidance.
  7. Using a tape measure, measure the length from the bottom of the ultrasonic depth sensor to the water surface. Measure the length from the bottom of the ultrasonic depth sensor to the bottom of the stream bed. Measure the length from the bottom of the ultrasonic depth sensor to the bottom of the stream bed.
    • Using a tape measure, measure the length from the bottom of the ultrasonic depth sensor to the water surface.
    • Measure the length from the bottom of the ultrasonic depth sensor to the bottom of the stream bed.
  8. If foliage may block the solar panel from charging, trim some branches. This is a completely installed stream bed depth sensor node!
    • If foliage may block the solar panel from charging, trim some branches.
    • This is a completely installed stream bed depth sensor node!
  9. Sometimes two strut channel arms are preferred over one. Attach a second 1 ft strut channel arm using the same hardware as the first strut channel arm.
    • Sometimes two strut channel arms are preferred over one.
    • Attach a second 1 ft strut channel arm using the same hardware as the first strut channel arm.
    • Use the node enclosure to determine how far apart the two arms need to be.
    • Tighten the screws with the impact drill.
  10. Place four screws into the node enclosure with the washer and strut channel nuts on the backside. You can remove the strut channel nut spring to make installation easier. Slide the node into the strut channel arm.
    • Place four screws into the node enclosure with the washer and strut channel nuts on the backside.
    • This is what the node looks like attached to two strut channel arms.
Abschluss
Brooke Mason
2.865 Reputation
17 Anleitungen geschrieben
Open-Storm Mitglied von Open-Storm
Community
20 Mitglieder
27 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 165
