Was du brauchst
Minimize exposure to items that can charge up and produce static electricity.
Use an anti-static wrist band.
Be gentle to not pull with to much force when removing power cables.
Verify that the notch in the connector matches the motherboard before sliding in.
Carefully slide in GPU until you hear a click on the motherboard.
Flip power supply switch back to on.
Plug in PC and turn on.
If PC does not post go back through the steps to see if you missed something.
Go to manufacturer's website or use the CD that came with the card to download the latest drivers for the GPU to ensure better stability of GPU.
3 weitere Personen haben diese Anleitung absolviert.
