Zum Hauptinhalt wechseln
Asus Eee PC 1015PN motherboard dismantling (English)
Was du brauchst
  1. Asus Eee PC 1015PN  motherboard dismantling (English), Motherboard: Schritt 1, Bild 1 von 2 Asus Eee PC 1015PN  motherboard dismantling (English), Motherboard: Schritt 1, Bild 2 von 2
    • To remove the battery, unlock the marked tabs.
  2. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 2, Bild 1 von 3 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 2, Bild 2 von 3 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 2, Bild 3 von 3
    • To remove the memory, lift the plastic tab covering the memory screw with a small slot head screwdriver.
  3. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 3, Bild 1 von 2 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 3, Bild 2 von 2
    • Lift the plastic cover and remove the SO-DIMM module.
  4. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 4, Bild 1 von 2 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 4, Bild 2 von 2
    • Remove the dummy SD-Card
  5. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 5, Bild 1 von 2 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 5, Bild 2 von 2
    • Unscrew 4 screws that are located in the battery compartment. Once removed, plastic tabs need to be removed on the upper part.
  6. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 6, Bild 1 von 2 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 6, Bild 2 von 2
    • With an extraction tool, separate the keyboard chassis from the netbook, it has many tabs.
  7. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 7, Bild 1 von 2 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 7, Bild 2 von 2
    • While separating the keyboard chassis, be careful with the keyboard connector. To remove it, simply slide the plastic retainer to be able to free it.
  8. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 8, Bild 1 von 2 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 8, Bild 2 von 2
    • Unscrew the marked screws. One of those screws is behind a warranty sticker.
  9. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 9, Bild 1 von 2 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 9, Bild 2 von 2
    • Disconnect the mouse connector. The connector has a white plastic tab that disconnects the connector.
  10. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 10, Bild 1 von 3 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 10, Bild 2 von 3 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 10, Bild 3 von 3
    • With a flat screwdriver, release two plastic tabs ( 1 on each side), and with pressure in the front, release the chassis.
  11. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 11, Bild 1 von 2 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 11, Bild 2 von 2
    • To disconnect the hard drive, two connectors need to be removed, pay attention to the connectors sides, the one on the left in marked as MB and the right is marked as IO.
  12. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 12, Bild 1 von 3 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 12, Bild 2 von 3 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 12, Bild 3 von 3
    • Remove the screws, and slide the hard drive free.
  13. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 13, Bild 1 von 1
    • Disconnect the motherboard connector and the IO plate.
  14. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 14, Bild 1 von 2 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 14, Bild 2 von 2
    • Remove the fan connector, the BIOS battery and the upper connector.
  15. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 15, Bild 1 von 3 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 15, Bild 2 von 3 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 15, Bild 3 von 3
    • Remove the plate screws and release the screen connector.
  16. Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 16, Bild 1 von 2 Asus Eee PC 1015PN  motherboard dismantling (English): Schritt 16, Bild 2 von 2
    • Remove the motherboard from the chassis, and disconnect a connector that is glued.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
es en
100%
DeZom hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
2 Kommentare
Joder la que hay que liar para cambiar el disco duro.
Rafael Belmonte - Antwort
Thank you for the guide
ilcaccillo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 46
Insgesamt: 13,696
