Einleitung
Steps to dismount the Netbook Asus Eee PC 1015PN
Was du brauchst
To remove the memory, lift the plastic tab covering the memory screw with a small slot head screwdriver.
Unscrew 4 screws that are located in the battery compartment. Once removed, plastic tabs need to be removed on the upper part.
With an extraction tool, separate the keyboard chassis from the netbook, it has many tabs.
While separating the keyboard chassis, be careful with the keyboard connector. To remove it, simply slide the plastic retainer to be able to free it.
Disconnect the mouse connector. The connector has a white plastic tab that disconnects the connector.
With a flat screwdriver, release two plastic tabs ( 1 on each side), and with pressure in the front, release the chassis.
To disconnect the hard drive, two connectors need to be removed, pay attention to the connectors sides, the one on the left in marked as MB and the right is marked as IO.
Remove the motherboard from the chassis, and disconnect a connector that is glued.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
DeZom hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
2 Kommentare
Joder la que hay que liar para cambiar el disco duro.
Thank you for the guide
