Einleitung
This is a prerequisite for working any further on the electronics box. It is far easier to set aside the speaker casing and work on the electronics box alone.
Was du brauchst
Remove the 8 Phillips screws from the back of the speaker.
Carefully remove the back panel, lifting out the metal electronics-box with it.
There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
Snake the clip head through the hole in the metal electronics box casing.
4 weitere Personen haben diese Anleitung absolviert.
