Einleitung
One of the types of brake slave cylinder on this tractor is a hydraulically assisted type.
This uses 18 bar hydraulic fluid that actuates the brakes. A common problem is rust building up inside the hand brake mechanism. This is a disassembly guide since most manuals don't seem to show how. New cylinders are also very expensive.
First we will remove the adjuster bolt, untighten the nut with 17mm spanner and then unscrew the bolt with a 8mm spanner.
Remove this bigger lock ring taking care since the spring is under some tension.
If your cylinder is in good condition you might be able to get the piston out with compressed air but mine is rusted in place.
So I used a greasegun and some special fittings. A brake pipe fitting threaded for a grease nipple.
Replace the air bleed nipple with the greasegun nipple.
Plug the hydraulic inlet and use the greasegun to force the parts out.
First comes the plunger that in this case was rusted in place.
Next the piston.
Next turn it over and use a 17mm spanner to remove the hand brake arm bolt.
Then using a scribe mark the end positions for the arm so you can get it back in the right rotation. Both the arm and the inner pusher have splines so this is a good thing to do.
The handbrake axle is locked by a small pin marked with the red arrow. I used a welder and a slidehammer to remove this.
Next use the slidehammer and a m10 threaded end to remove the habdbrake axle like in picture 2.
Now we will have to separate these two parts to get the handbrake actuator out.
Using a m10 bolt and a metric pipe thread I forced the to rotate in different directions which broke them free,
Now the top part can be removes followed by the handbrake actuator and lastly the lower part.
