Zum Hauptinhalt wechseln
Dewalt DCD778 Forward/Reverse Switch Replacement
Was du brauchst
  1. Dewalt DCD778 Forward/Reverse Switch  Replacement, Battery: Schritt 1, Bild 1 von 1
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Forward/Reverse Switch  Replacement: Schritt 2, Bild 1 von 1
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Forward/Reverse Switch  Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: Schritt 4, Bild 1 von 1
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Forward/Reverse Switch  Replacement: Schritt 5, Bild 1 von 1
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Forward/Reverse Switch  Replacement: Schritt 6, Bild 1 von 1
    • Remove the drill mechanism from the shell.
  7. Dewalt DCD778 Forward/Reverse Switch  Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
    • To replace just pull the switch out and put the new one in the opening.
Abschluss
Brittany
705 Reputation
5 Anleitungen geschrieben
Casper College, Team S1-G5, Lareau Spring 2019 Mitglied von Casper College, Team S1-G5, Lareau Spring 2019
CASC-LAREAU-S19S1G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 51
Insgesamt: 2,026
