Zum Hauptinhalt wechseln
Dexcom G6 Receiver Charging Port Replacement
Was du brauchst
    1. Dexcom G6 Receiver Charging Port Replacement, Display and Front Bezel: Schritt 1, Bild 1 von 1
      • Unscrew the 6 Torx T5 screws from the back of the device
      Frag FixBot
      Kommentar hinzufügen
    2. Dexcom G6 Receiver Charging Port Replacement: Schritt 2, Bild 1 von 2 Dexcom G6 Receiver Charging Port Replacement: Schritt 2, Bild 2 von 2
      • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
      • Screen Information: Model AM0310R-04 Lot # NHT18080052
      Frag FixBot
    1. Dexcom G6 Receiver Charging Port Replacement, Charging Port: Schritt 3, Bild 1 von 1
      • Using a spudger, unplug the Charging Port connector from the motherboard.
      Frag FixBot
    2. Dexcom G6 Receiver Charging Port Replacement: Schritt 4, Bild 1 von 1
      • Remove the 2 silver Torx T5 screws holding the charging port down.
      Frag FixBot
    3. Dexcom G6 Receiver Charging Port Replacement: Schritt 5, Bild 1 von 1
      • Remove the Charging Port Assembly from the motherboard.
      Frag FixBot
Abschluss
Andrew S
15.619 Reputation
8 Anleitungen geschrieben
5 Kommentare zur Anleitung
Where can the part be purchased?
Mayor of Koala Corner - Antwort Teilen
I'm not sure if there is a replacement charging port assembly available online. If you're good at microsoldering, you could replace the surface mount micro USB port on the assembly.
Andrew S - Antwort Teilen
where can the part be purchased?
would a cell phone repair shop be able to do this?
Ron Magliacane - Antwort Teilen
If they are comfortable with it. Tell them it will probably require microsoldering.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 31
Insgesamt: 1,272
