Zum Hauptinhalt wechseln
Dexcom G6 Receiver Display and Front Bezel Replacement
Was du brauchst
    1. Dexcom G6 Receiver Display and Front Bezel Replacement, Display and Front Bezel: Schritt 1, Bild 1 von 1
      • Unscrew the 6 Torx T5 screws from the back of the device
      Frag FixBot
      Kommentar hinzufügen
    2. Dexcom G6 Receiver Display and Front Bezel Replacement: Schritt 2, Bild 1 von 2 Dexcom G6 Receiver Display and Front Bezel Replacement: Schritt 2, Bild 2 von 2
      • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
      • Screen Information: Model AM0310R-04 Lot # NHT18080052
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Andrew S
15.619 Reputation
8 Anleitungen geschrieben
7 Kommentare zur Anleitung
Where can the replacement parts be found? And a charging port?
Ron Magliacane - Antwort Teilen
Also looking 2 the display. Have 2 dexcom receivers here and both with broken displays.
Jeroen - Antwort Teilen
I'm not sure if you can find the displays anywhere. The only number (presumably model number) I could find on the screen was AM0310R-04 and the Lot Number NHT18080052.
Andrew S - Antwort Teilen
Sharewith us where we can find the displays to buy
I need assistance on a little project I’m working on requiring the display out of the dexcom receiver
Gregory Bassett - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 39
Insgesamt: 1,772
