Was du brauchst
Unscrew the 6 Torx T5 screws from the back of the device
Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
Screen Information: Model AM0310R-04 Lot # NHT18080052
Using a spudger, unplug the Charging Port connector from the motherboard.
Using a spudger, carefully remove the battery connector on the left side of the motherboard.
2 Kommentare zur Anleitung
do you know of anyone that can fix these items
anyone out there fix these items
