Einleitung
This tutorial shows you the change of only one carbon, to change the second you just have to follow the same method.
Was du brauchst
Remove the carbon from its housing then take it out.
Using pliers, fold down the small tab.
Fast fertig!
To reassemble follow guide through or in reverse
Abschluss
fr en
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
