Einleitung
This tutorial shows you the change of a single carbon, to change the second you just have to follow the same method.
Was du brauchst
Unscrew the six screws from the pad.
Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
Reposition the part, then lock the engine with a screwdriver to screw.
Put the tray back on and screw the screws.
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
